The Wall
Forum / Oil Heating / basi b10-3 or burnham mpo-84
  • Post a Reply to this Thread
    basi b10-3 or burnham mpo-84 (4 Posts)
  • polcat1p polcat1p @ 4:31 PM
    Contact this user
    which is better for baseboard heat(,3 zonse) and a zone for a indirect?
     i have a burnham allaince sl35 indirect, and i would like to add an odr.
    thanks
  • Robert O'Brien Robert O'Brien @ 9:41 AM
    Contact this user
    polcat
    There good restaurants,bad ones and great ones. Do the the ingredients make a difference? Absolutely,but the main difference is the chef!  The choice of boiler between one triple pass and another is barely worth discussing!
  • Steamhead Steamhead @ 11:19 AM
    Contact this user
    Agreed
    you can't go wrong with either one, unless it's improperly installed. Both are first-class units.
    Steam, Vapor & Hot-Water Heating
    Reducing our country's energy consumption, one system at a time.
  • polcat1p polcat1p @ 8:41 AM
    Contact this user
    bypass of p/s piping
    i picked the biasi boiler, its comming monday, along with circs and a aq251 controll should i do p/s or a bypass to keep the return temp up? is a bypass just a tee from the s to the r with a ball balve?
    thanks
