hot water pressure
i have an efm oil boiler. my problem is; i seem to have lost the hot water pressure. it just trickles out. the unit is 25 years old & never had this problem before. what could it be & how can i fix it. it is hard taking a shower, doing wash & running the dishwasher. i NEED help, it's making me crazy!!
I am assuming this is
an oil boiler with a tankless coil. The coil needs changed or acid washed most likely. are there any controls to limit water temperature such as a mixing valve? These may be clogged too. Try the find a contractor at the top of the page.
