The Wall
Forum / A-C, Heat Pumps & Refrigeration / Air Handler Howling
  • Post a Reply to this Thread
    Air Handler Howling (15 Posts)
  • Jerky_san Jerky_san @ 8:12 PM
    Contact this user
    Air Handler Howling
    I had my air handler serviced last year towards the end of the year. I used the air conditioner about twice after he had worked on it. It howled during this time but I didn't think anything of it since it didn't do it right after I turned the furnace on. This summer though I noticed it howls again so I did a little deducing. I found that it doesn't howl when just the fan is on. It doesn't howl when the furnace is on. It only howls when the A/C is running. I change the filter very regularly so I don't believe it is that. It drains properly since I clearly see it eject the water outside using a condensation pump.. The howling seems to be coming from a lower section of the air handler. Right above the fan where the furnace is. I'm fairly certain the sound is below the A coil. What I don't understand is if its coming from the furnace part of it why does it not make any such howling when the furnace runs. I'm including a wma file of the sound if that will give you a better hint. Any help would very much appreciated.
  • Techman Techman @ 10:05 PM
    Contact this user
    How-ler
    Is your fan "on " motor speed the same speed as your ac fan on speed ?
    Contact this user
    How-ler
    Contact this user
    How-ler
  • Techman Techman @ 10:10 PM
    Contact this user
    Triple play!!
    Must  have been my twitchy finger!!!!!!!
  • Jerky_san Jerky_san @ 10:14 PM
    Contact this user
    Yes
    As far as I can tell yes it is.
  • Techman Techman @ 10:16 PM
    Contact this user
    How -ler
    Turn the condensing unit disconnect off ,and give another listen.
  • Jerky_san Jerky_san @ 10:27 PM
    Contact this user
    Huh..
    So I turned the therm to off went outside and disconnected the condenser and turned it to cool.. And it makes the howl. Turned the ac off and ran just the fan and no sound.
  • Techman Techman @ 10:41 PM
    Contact this user
    O.K.
    Is the indoor blower motor a variable speed motor ? 16 SEER  system ?
  • Jerky_san Jerky_san @ 10:54 PM
    Contact this user
    System
    I don't know the SEER rating but I'm fairly certain its not variable.. Can't be positive about it but fairly certain its not. I moved into this house last year so thats why I don't know much about it.. Its an american standard model #CUB060A936C1 if that helps at all.. I can also say this.. generally around here they don't put very expensive A/C units in..
  • Jerky_san Jerky_san @ 9:33 PM
    Contact this user
    Something I can do
    Is there anything I can do to find out what type it has? Though I'm fairly certain now its not variable cause I'm pretty sure that would be a two stage type system and this is a one that I know of.
  • Jerky_san Jerky_san @ 8:20 PM
    Contact this user
    Speed Adjustment
    I have a lot more information now.. its a 4 speed 115v GE motor with an rpm rating of 1075. Since its a four speed motor do you think i could change the a/c part down to the next lowest speed and have it not make the noise anymore?
  • David Broome David Broome @ 10:20 PM
    Contact this user
    air handler howling
    it can't bark lol
    Contact this user
    air handler howling
    it can't bark lol
  • don don @ 5:49 AM
    Contact this user
    Distribution system to small
    What you have and i think this is the case is that when you swith the fan from auto to on without a call for ac the board in the furnace picks a lower speed.
    Now with a call for cool the board will choose  a higher speed for ac and there a reason for that.not going go into why bc whenever you make a change with fan speed one need to test static pressure and freon charge again to make sure the system is dail in correctly.
    In short making a fan speed adjusment could be a bad move without testing you made the right choice.
    Also it could be something as simple as a loose piece of tape or the doors on the coil casing is loose and air is trying to get out the crack and give you a noise.
