The Wall
Forum / A-C, Heat Pumps & Refrigeration / Inefficient compressor
  • Post a Reply to this Thread
    Inefficient compressor (7 Posts)
  • paul s paul s @ 8:52 PM
    Contact this user
    What are the signs of a imefficient compressor??
  • JStar JStar @ 9:06 PM
    Contact this user
    Typically.
    Abnormally high suction, and low discharge. The compression ratio will be very low.
    If you suspect a weak compressor, you should pump down the unit to a low number on the suction side and watch the gauge for any movement. If a valve is bad, the pressure will feed back and the low side will rise.
  • Techman Techman @ 5:00 AM
    Contact this user
    Inefficient comp
    The leaking back of hi press to the low side is true w/ leaking/bad discharge reeds . What about bad/leaking suction reeds?Is this a scroll or a recip comp?
  • Del Del @ 11:58 AM
    Contact this user
    scrolls
    I've been told not to pump down using scroll compressors.
  • Techman Techman @ 12:37 PM
    Contact this user
    Scroll pumpdown
    Sure you can!!!!!!!!!!!!!!!!!!Been doing it for years ,20 -25 or so that is!
  • don don @ 6:58 AM
    Contact this user
    scroll pumpdown
    You can pump down a scroll as long s you do not pump it down into a vaccum.I herd if you pump it down into a vaccum it could arc and cause a burnout.
  • Techman Techman @ 9:22 AM
    Contact this user
    Scroll pumpdown
    There is a trick to a Scroll pumpdown,though!Out of the "box" a Scroll cannot be used on a pumpdown.
