The Wall
Forum / Oil Heating / Firomatic Fusible Oil Valves
  • Post a Reply to this Thread
    Firomatic Fusible Oil Valves (5 Posts)
  • brentt brentt @ 10:23 AM
    Contact this user
    I am doing some research for a paper on oil heating. I live in Massachusetts where they use a thermal cut-off switch above the oil burner that will disconnect the power to the burner should the temperature reach 165 degrees. They also use an oil safety valve that stops the flow of oil should the same condition occur. I believe this is part of the Massachusetts code. Does anyone know if other states require the use of such devices?
  • Steve Steve @ 6:42 PM
    Contact this user
    firematic valves
    in  Maine,  we  follow   NFPA  #31    closely... //    thermal  electric    firematic  above  burner   ///     firematic    oil   valves  at  the   oil tank,   &   at the burner..
  • meplumber meplumber @ 7:09 PM
    Contact this user
    As steve stated.
    I am in Maine as well. I think you will find that most all states that burn fuel oil follow NFPA #31 very closely. With some even more stringent than the NFPA guidance.
  • lchmb lchmb @ 8:39 PM
    Contact this user
    ayuh
    New Hampshire is on board with that ruling also..:)
  • billtwocase billtwocase @ 9:44 PM
    Contact this user
    It's been code
    for decades here in Mass
