The Wall
Forum / Gas Heating / intertherm furnace
  • Post a Reply to this Thread
    intertherm furnace (3 Posts)
  • karbear64 karbear64 @ 5:30 PM
    Contact this user
    intertherm furnace
    I have an mobile home...the furnace is an intertherm  model # mimb070abw.....the red led light is flashing twice.....it says on the furnace that the "pressure switch is open" was wondering what that meant and also what is a pressure switch???  ( I use LP gas)
                                                             Thank you......
  • Tim McElwain Tim McElwain @ 6:56 PM
    Contact this user
    When the furnace comes on
    from all call for heat from the thermostat a blower is energized which brings air to mix with the gas for burning. However before the gas valve can be energized to open and allow gas to flow the "pressure switch" must switch over to power the gas valve. If the pressure switch will not prove the system will not operate.
    There could be a blockage or a plugged condensate line, call a professional to come and diagnose and repair your problem.
  • Empire Empire @ 3:01 AM
    Contact this user
    Call Professional
    In addition to Tims comment, please do not try to fix it yourself.  This is potentially a deadly problem that needs to be identified.  Do not jump out any safety switches even for temporary heat!
