The Wall
  • Post a Reply to this Thread
    unico system (5 Posts)
  • polcat1p polcat1p @ 8:07 PM
    Contact this user
    unico system
    hello
    i have a unico mc2430/mb2430 system. i dont have a compreser yet, and was wondering what would be a good buy. may be a good heatpump?
  • counterman counterman @ 8:36 PM
    Contact this user
    Heat pump
    I would make sure you have a heat pump coil (mc2430h). Unico has a different dx coil for heat pumps. I would recommend 13 or 14 seer maximum. A higher seer condensing unit would not achieve and greater efficiency. Also warranties on the condensing unit may be reduced because it is not part of a "ahri matched system"
  • polcat1p polcat1p @ 10:18 PM
    Contact this user
    unico system
    thanks
    its a 2430hx.
  • polcat1p polcat1p @ 10:12 PM
    Contact this user
    410a unico tx valve
    was also wondering if my unit has the 410tx valve. i assume it does, because i have all the paper work, and they used a american standard heat pump that has 410. i looked at the valve and see a few numbers
    45 zga
    bp/15
    4405
     none of these seem to match the a00808-012 the book says.
    im also still looking for a good match heatpump for this unit, any ideas?
    thanks
  • polcat1p polcat1p @ 10:08 PM
    Contact this user
    unico
    maybe just going to do ac only. what is a good seer and model condenser/
    thanks
