The Wall
Forum / Oil Heating / Conversion of a new steam boiler to hot water.....
  • Post a Reply to this Thread
    Conversion of a new steam boiler to hot water..... (10 Posts)
  • Bub Bub @ 5:57 PM
    Contact this user
    Last winter my furnace puffed, sending black soot throughout my freshly painted interior. I had a friend (a commercial boiler repairman) come over to fix it. He found a crack in it, repaired it with furnace cement and told me to start shopping for a replacement. I found one on e-bay, I thought I had asked all the right questions and purchased a brand new Weil McLean to replace my old one. Well as luck would have it when I begam to install it I found out that the new boiler is a steam boiler. My question is this; Can the new unit be converted to hot water?
  • Steamhead Steamhead @ 9:11 PM
    Contact this user
    What model
    is it?
    Steam, Vapor & Hot-Water Heating
    Reducing our country's energy consumption, one system at a time.
  • Bub Bub @ 9:43 AM
    Contact this user
    Steam Boiler Conversion
    Hi,
     The new boiler is a Weil McLean SGO-5, Series 3
  • Charlie from wmass Charlie from wmass @ 9:31 PM
    Contact this user
    The quick answer is yes
    The problem is it will probably use up all the money you saved and more to get the water controls. You could Ebay the steam trim to try and get back some of your money.
  • lchmb lchmb @ 11:54 AM
    Contact this user
    change
    They offer a service manual for hot water so one would assume with removing the steam portion of the system you can use it for Hydronic
    http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/boilers/oil-boilers/sgo/550-141-828_1202.pdf
  • Charlie from wmass Charlie from wmass @ 9:27 PM
    Contact this user
    That boiler is able to use a power gas burner
    The Carlin EZ gas burner can be installed on it without warranty issues.
  • Bub Bub @ 12:01 PM
    Contact this user
    SGO-5
    I want to convert this boiler to oil hot water
  • lchmb lchmb @ 1:07 PM
    Contact this user
    yes
    just need to purchase they hydronic controls and some plugs...
  • Bub Bub @ 1:11 PM
    Contact this user
    SGO-5
    Would I be able to use the ones on my existing furnace?
  • lchmb lchmb @ 1:16 PM
    Contact this user
    recommend
    without seeing what you have I cant answer that. I would however recommend you purchase a new aquastat. You'll need the well and a 30 psi pressure relief valve, alway's start new with the pressure relief valve, it's a safety and you dont want an old one that may not function...Also add a triadicator...
