Forum /
Oil Heating /
weil mclain wgo3
Post a Reply to this Thread
weil mclain wgo3 (8 Posts)
weil mclain wgo3
just installed with beckett genesis control, lights, then control chatters, then locks out. did not contact becett yet. any ideas -
connections
Is the control going to lockout? Or chattering and shutting off completely..no light's visible.. -
chatter
Could be a defective control, but I would check all wiring, voltage input reading, secure all grounds including case grounding, etc. It most likely has a low water cut off aquastat. What lights are lit on top? -
Wgo3
I'm going back today to check. it does have a aquastat with a low water cut off -
Solution?
went back on job today, hooked up my contractors tool ,turned on power switch. no chattering. but 3 cycles showed pre time flame .I set up the burner and everything seems fine. Ran it threw a few cycles with the thermostats , it ran fine. Thanks for the input ! -
Solution?
I would
Check your clean cut pump. The stem was stuck open? Is it programmed for pre-purge? -
Had some chattering
after we accidentally spritzed a Genisys with water . Didn't want to take a chance so we just swapped it out .
