Forum /
Gas Heating /
Peerless Purefire
Post a Reply to this Thread
Peerless Purefire (4 Posts)
Peerless Purefire
I have a Peerless Purefire Boiler (3-years-old) that is omitting a gas smell, between the gas shut-off valve and the burner. I have checked for leaks on all of the joints, and no leaks are present. Even if the boiler is idle, the smell still exists. The smell only goes away, it I close the gas shut-off (which is why it's between the gas shut-off valve and the burner). Would anyone know what else could be going on here?
Thank You -
Did you check the
tail screw on the gas shut off? How did you test for leaks? I hope it was with a soap and water solution using a brush to wet-down the fittings then looking for bubbles. Please no open flames to test for leaks. If the smell persist call the local gas company and have them do a survey with a well calibrated instrument for detecting gas leaks. -
Stainless steel flair fittings
There are flair fittings on the flexable line inside the unit. It takes some oomph to get them tight.
-Andy -
Maintenance
I am using a Gas Detector, and it's not showing any leaks. The smell seems like it's coming from the gas valve. I plan to do a cleaning on this boiler today, since it's been three years that the customer has it, wihtout any maintenance being performed. Those flare fittings were one of the first things I checked.
