The Wall
Forum / Gas Heating / Burnham PVG6NI Whistling Noise
  • Post a Reply to this Thread
    Burnham PVG6NI Whistling Noise (4 Posts)
  • rsc92 rsc92 @ 1:36 PM
    Contact this user
    I have a Burnham PVG6NI gas fired boiler. This is a power vent unit. When the t-stat calls for heat, the inducer fan starts up and I hear a whistling noise. This continues even after the gas lights, but seems to subside once the unit gets hot. I have replaced the fan gasket, but that did not help. I have also disconnected (momentarily) the exhaust ductwork, but the whistiling persists, so I know it is being caused inside the boiler itself.
    Anyone know what could be causing this (or experienced and repaired this themselves)?  Thanks
  • Tim McElwain Tim McElwain @ 4:38 PM
    Contact this user
    Try spraying a little
    WD-40 on the fan blade.
  • rsc92 rsc92 @ 3:23 PM
    Contact this user
    Fan
    Thanks for the suggestion.  The noise is not the fan itself.  Take the fan out and the fan (while it is running) does not make this noise.
    Any other thoughts??
  • Tim McElwain Tim McElwain @ 11:35 PM
    Contact this user
    Check your inlet and
    outlet gas pressure.
    Have a combustion analysis done on the unit and insure you are firing the equipment at its maximum firing rate.
