The Wall
Forum / Gas Heating / When the electricity goes out...
  • Post a Reply to this Thread
    When the electricity goes out... (3 Posts)
  • njwebdevguy njwebdevguy @ 6:08 PM
    Contact this user
    What can be done with a gas furnace /hot water heat in a power outage.
    My circulator pump and the thermostat/aquastat/24 volt transformerruns off of 115 volts.. Is it possible to use a furnace in a blackout somehow. The reason I ask is that recently the electricity went off for several days and everyone in our neighborhood was freezing. The temps went below freezing but not long enough to burst pipes.. but if it had been a little worse, it would have.
    What kind of gas/water heat can take this licking and keep on ticking?
    Preferably using less current in emergencies.. Can any just run on gas, no 115v? Its not whole house confort I'm necessarily seeking, just protection from bone chilling cold and below freezing, pipe bursting temps.
    I live in northern NJ. Not in the mountains, more like the foothills.. (its not as cold here as there)
  • lchmb lchmb @ 6:49 PM
    Contact this user
    empire
    or similiar make wall mounted unit's that run on millivolt system's. You could look into that or a small gas log as an emergency back up to keep some heat in the house during a power outage. The only other thought would be to purchase a small generator and wire it into a transfer switch for the boiler only..
  • njwebdevguy njwebdevguy @ 11:01 AM
    Contact this user
    digital gas log...
    We've all seen those DVDs they sell of roaring fires that some people use to create holiday spirit. This device digiitizes it.
    http://hackaday.com/2011/11/03/interactive-digital-fireplace-is-great-for-those-chilly-winter-evenings/
