The Wall
Forum / Oil Heating / Proper Riello F3 for use with outside combustion air
  • Post a Reply to this Thread
    Proper Riello F3 for use with outside combustion air (7 Posts)
  • Brent H. Brent H. @ 11:53 PM
    Contact this user
    Greetings,
    So my contractor is starting tomorrow to install a new 3 section Buderus G115WS in my basement but we've gotten a bit of conflicting information from supply houses and Buderus. For the install, I asked him to make sure the burner will support a connection for outside combustion air. The supplier told him that the Riello BF3 burner was needed. He then talked to Buderus and was told that the BF3 is meant for direct vent applications and we should use the F3 which now has a knockout for outside air. Looking tonight at the manual for the F3 in the spare parts drawing, the ducted combustion air intake kit(part#3002761)is shown with only a checkmark next to it in the F5 column, not the F3. Is the kit only valid for the F5 or does it just not come standard with the F3? Has anyone used a F3 burner with outside combustion air?
    Thanks.
  • R Mannino R Mannino @ 2:05 PM
    Contact this user
    The F3
    that comes with the G115 has the knockout. As long as it's not old stock.
  • Brent H. Brent H. @ 5:41 PM
    Contact this user
    4" Adapter
    Have you been buying the adapter from Reillo or just using a standard stick-on one? Do you block the stock air intake in the cover or leave it open?
    Thanks.
  • Robert O'Brien Robert O'Brien @ 7:31 PM
    Contact this user
    Sealed combustion?
    If you want sealed combustion,you need a BF. If you just want to use outside air,the standard knockout and collar is the cheapest. EK makes a nice adapter that doesn't need to be removed every time you take the burner cover off
    This post was edited by an admin on November 4, 2011 7:35 PM.
  • Brent H. Brent H. @ 9:58 PM
    Contact this user
    Outside Air
    I'm mostly just trying to reduce infiltration a bit. It's funny, one person at Buderus told me that the BF could be used but a savy tech. was needed to setup the burner. Another person at Buderus told me you couldn't use the BF with a chimney...... they need to get their stories straight. We actually have both burners at the house since we weren't sure which to use. In the end, I'll probably just use the F3 since it's all setup for the chimeny vent boiler.
    I'm still curious if the Riello kit for adding outside air includes a plate to cover the vent in the cover.
    -Brent
  • Ron Jr. Ron Jr. @ 10:36 PM
    Contact this user
    I had a BF3 on my standard oil boiler
    for years without an issue . It was ducted to the outside with 3 inch PVC . I'm not sure of the noise level with the newer F3 covers ( if it's ducted to the outside ) but the BF3 cover is extremely air tight and cuts the noise down considerably . Compared to a regular , unducted F3 .
    I have a Beckett NX now ( like in Bob's 2nd pic ) and it's even quieter than my old BF3 .
    This post was edited by an admin on November 4, 2011 10:38 PM.
  • R Mannino R Mannino @ 7:02 PM
    Contact this user
    We Prefer the NX for Outside Air
    It's easier and quieter too
