The Wall
Forum / THE MAIN WALL / please identify
  • Post a Reply to this Thread
    please identify (10 Posts)
  • N/A @ 9:54 AM
    please identify
    This is an interesting forum. I don't know if this is the correct place
    to post this but can someone tell me what I have in these photos. It
    is about 4 1/2 feet high x 4 feet wide x 7 feet deep. It is in the
    building I just bought. I looked for information on US Radiator Corp
    and found nothing.
    Thanks,
    Arnold
  • Tim McElwain Tim McElwain @ 12:04 PM
    Contact this user
    It is an old
    boiler that probably was used to heat the building. As it looks from your pictures it has not been used in a long time as a heating system. Is there some other means of heat in the building?
    If you are thinking of restoring it I would say not the best idea. It would be best to go with a new system from scratch.
    What kind of emitters do you have? radiators, convectors etc.
  • seabiscuit seabiscuit @ 1:02 PM
    Contact this user
    please identify
    The boiler in the photos is not hooked up anymore and hasn't been used in many years.   I don't know what type of emitters or convectors but there are some tall radiators in the above floors. I don't know what types but will look for names. Someone said the red top may be significant to type of boiler?
  • Tim McElwain Tim McElwain @ 1:51 PM
    Contact this user
    Some pictures of
    the radiators would help to identify if it was a steam system or hot water.
  • Robert O'Brien Robert O'Brien @ 2:24 PM
    Contact this user
    Steam
    It's steam,the upper gauge glass cock is visible as well as the tapping for the missing lower cock. It's worth 16 cents/lb here
  • Tim McElwain Tim McElwain @ 5:04 PM
    Contact this user
    Steam it is
    just spotted the pig tail in the first picture.
  • Eric Eric @ 6:02 PM
    Contact this user
    My guess..
    There's about 1600-2000lbs of cast iron there waiting to get recycled.
  • JStar JStar @ 7:39 PM
    Contact this user
    RE
    Save the gauge!
  • seabiscuit seabiscuit @ 9:45 AM
    Contact this user
    So,
    So, it's cast iron that can go to the scrap yard.   Thanks for the i.d.  Is there any way to turn it into a wood stove?  or a blacksmithy's forge?  or something useful?  Thanks again
  • Mark Eatherton Mark Eatherton @ 8:50 PM
    Contact this user
    Alternative use....
    I have used these cast iron behemoths as a heating radiator before, and they work fantastic. Hook it up to the supply and returns, and install a non electric thermostatic radiator control valve to it, and let the 500 pound radiant gorilla in the corner heat your basement. Clean it up, fix it up, spit polish it, hand paint the raised letters, and even throw an electric light bulb that looks like a flickering flame into the fire box for effect, and it makes a GREAT conversation piece.
    If you intend to recycle it through a metal recycler, be prepared to spend at least one day on the end of a sledge hammer, and another carting the pieces out of your house and into the yard, then into the truck.
    Re-use is better than recycle...
    ME
    It's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.
