The Wall
Forum / THE MAIN WALL / thermostat wire
  • Post a Reply to this Thread
    thermostat wire (6 Posts)
  • ChrisJ ChrisJ @ 4:10 PM
    Contact this user
    thermostat wire
    This may be a cheesy question but can I use 18AWG copper 2 conductor stranded wire for my thermostat?  I know it calls for 18AWG but I always see solid wire on them and don't want to violate code.
    Its 2 conductor non shielded in a single black jacket I think black and white colors if it matters.  I realize it will work fine, but will it be to code?  I will of course tin the ends to keep them from fraying.
  • Jamie Hall Jamie Hall @ 4:49 PM
    Contact this user
    Code may vary
    from place to place.  Of considerably more interest, from a practical point of view, is the overall rating of the wire -- temperature, voltage.  Stranded or not stranded probably is not relevant -- but temperature and voltage ratings will be.
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • ChrisJ ChrisJ @ 4:54 PM
    Contact this user
    temp rating
    rated for 105C looks like it has a UL listing as well type CL2R.
    I would think the voltage rating would be irrelevant as its for a 24V system.  I'm sure the wire is good for more than 100v.
    This post was edited by an admin on November 18, 2011 4:59 PM.
  • Jean-David Beyer Jean-David Beyer @ 5:14 PM
    Contact this user
    I do not know codes, but...
    for things like wiring thermostats, I would think solid wire to be better than stranded, because it is too easy to let a strand get loose and short out an adjascent terminal. I know it can be done, but not if you are in a hurry.
    Stranded wire seems more suited to something that needs to be moved frequently, such as a floor lamp, not something in a wall that moves only during earthquakes and demolitions.
  • Techman Techman @ 5:25 PM
    Contact this user
    T'stat wire
    for regular thermostats ,like you have,can be either.As JDB said ,watch out for loose strands. So strip back the insulation and twist the strands a few times real good . I think the volt rating is 85v or 90v.
    This post was edited by an admin on November 18, 2011 5:27 PM.
  • ChrisJ ChrisJ @ 5:50 PM
    Contact this user
    strands
    Appreciate the responses.
    Like I said I'll be sure to tin the ends of the wires so there won't be any loose strands.  I want to use it because we have a huge spool of it where I work and the boss doesn't mind me taking 30 feet or so.
