MacDonald Miller Uni-Match Water Feeder
Hello Guys, I am a handy Homeowner. I was checking out my automatic Water feeder; I was wondering if the cap underneath it is used for cleaning? If I shut off the water supply to it, would it be wise to even attempt to clear/Clean it? It is on pretty tight, I did not wanna break the small 1/2 Inch copper pipes serving it?
Question#1 is that brass screw cap for flushing it?
#2 Should I even bother?
The installation is about 5 years old
Unless it gets plugged
I wouldn't open it. There is a strainer in there, but unless it needs cleaning............
Steam, Vapor & Hot-Water Heating
Reducing our country's energy consumption, one system at a time.
old saying (nice terms)
"if it aint broke, you cant fix it...but you sure can screw it up"....
