The Wall
Forum / THE MAIN WALL / Damped Temp on Viessmann Vitogas 100
  • Post a Reply to this Thread
    Damped Temp on Viessmann Vitogas 100 (3 Posts)
  • jim jim @ 10:59 AM
    Contact this user
    I have a Viessmann Vitogas 100 with vitotronic 200 control. One heat circuit with 2 zones currently running const. circulation using outdoor reset. The outdoor temperature monitor is on the northwest wall. No remote vitotrol 200 or 300 at this time. Thinking of adding 300 in open zoned area.
    What is damped temp mean? Currently it is set at 15. Is that correct for this set up?
    Thanks for your help.
    Jim
  • Simply Rad Simply Rad @ 11:47 AM
    Contact this user
    damped temp
    Jim
    You have 2 temperatures displayed for the OTS(outdoor temp sensor).  Actual temp is the temp right now and the damped temp is the temp that was last recorded and used in the heating curve.  The control uses a temp reading or recalibrates the heating curve over a period of time.  It does not just use the actual temp for the heating curve formula.  I believe in coding level 2 you can chose the duration of time between each time the control recalibrates the heating curve using the OTS reading or damped temperature.  I live in colorado where the outdoor temperature changes each morning and evening 20 degrees in an hr.  So I have the control check the temperature every hour.  Hopefully that makes sense.
    BTW constant circ with indoor feedback is a great way to control a radiant system, but keep in mind indoor feedback is a very powderful control.  You are controlling the whole heating circuit with one sensor.
    Good luck
    Jeffrey
  • jim jim @ 12:58 PM
    Contact this user
    damped Temp
    Thanks Jeffrey
    If I read the manual correctly 15 would equal 150 min. and your setting of 1 hour would equal your setting of 6 as it is the number x 10.
    Thanks
    Jim
