The Wall
Forum / Radiant Heating / radiator air valve leaking question
  • Post a Reply to this Thread
    radiator air valve leaking question (4 Posts)
  • tom83 tom83 @ 8:01 PM
    Contact this user
    Hello,
    I have a question about a leaking air valve, lately its been spewing out hot water and steam. My question is it a matter of replacing the air valve? I have attached pictures of the radiator. Any help is appreciated.
  • furnacefigher15 furnacefigher15 @ 10:16 PM
    Contact this user
    Replace the valve
    It's likely time to start replacing all those those little buggers.
    Just noticed the piping arangement
    Is this a hot water boiler?
    This post was edited by an admin on December 12, 2011 10:18 PM.
  • tom83 tom83 @ 10:39 PM
    Contact this user
    reply
    Yes, this is a hot water boiler. I am not sure what to replace them with? Thanks.
  • Jean-David Beyer Jean-David Beyer @ 7:02 AM
    Contact this user
    Are you sure?
    I am not a professional, but I never heard of putting steam vent valves on hot water radiators. Also, I would think for a hot water system, there would just be a little coin valve on the radiator, and the supply and return pipes would be on opposite ends of the radiator.
    On the other hand, if it is a steam system, that vent valve would be on the opposite end of the radiator from the steam entry pipe and about half way down..
