The Wall
Forum / Strictly Steam / breaking loose steam traps
  • Post a Reply to this Thread
    breaking loose steam traps (7 Posts)
  • rk123 rk123 @ 3:59 PM
    Contact this user
    we are on a job had pipe heated to orange glow 2 guys with 2 pipe wrenches we can not break lose the fittings, please help I figured 2 guys 6 hours each, we are 4 hours into the first one
  • Rod Rod @ 4:15 PM
    Contact this user
    Use an Impact Wrench
    Hi- I've had the best luck using an impact wrench. I have an pneumatic wrench but you can also get them electric, either battery or cord. Home Depot has pneumatic, cordless and cord.
    - Rod
  • MotownSteamer MotownSteamer @ 5:32 PM
    Contact this user
    I was not able
    to get my caps off. I don't think they were ever serviced (88 years). When I removed them from the radiator and pipe, I put them in a vise. Using a cheater bar and pipe wrench, I finally got the caps off, but egged the fitting.
    If they are that bad replace the whole shooting match.
  • MikeyB MikeyB @ 5:54 PM
    Contact this user
    Heat & candle
    While using heat on the fittings stick a candle into the thread, it will suck it in to lubricate the threads, if you don't have a candle use a Wax ring, works just about all the time
  • Hap_Hazzard Hap_Hazzard @ 10:16 PM
    Contact this user
    Impact
    Impact is your best option. If you don't have an impact wrench or air hammer you can do it the old-fashioned way with a hammer and cold chisel. If the fittings are malleable you can notch them and then drive them at a tangent from every possible angle to try to unscrew them. If they're hard cast you can usually break them with a big enough hammer.
    Heat is only helpful if you can heat the fitting faster than the pipe, or heat both and rapidly cool the pipe so it contracts and fractures the hardened pipe joint compound that's locking the threads. You can sometimes loosen them up just by persistently beating the fittings with a hammer, but if you only hit it in one or two places you can deform it, making it harder to turn even if the threads break loose
  • Charlie from wmass Charlie from wmass @ 10:30 PM
    Contact this user
    Try to tighten them first
    After heating and waxing tighten them just a bit then loosen them.
    Contact this user
