The Wall
Forum / Strictly Steam / Kohler Steam Radiators
  • Post a Reply to this Thread
    Kohler Steam Radiators (4 Posts)
  • Positive Solution Positive Solution @ 7:36 AM
    Contact this user
    Hello,
    I have old Kohler radiators in my house. I am trying to compute the total sq. ft of steam. Does anyone know where I could find rating charts on Kohler radiators circa 1940. The only thing I could find on this site is an old Kohler brochure which does show the radiators but there are no rating charts. Thanks for your help.
  • ChrisJ ChrisJ @ 10:49 AM
    Contact this user
    Kohler
    I'm not sure which ones you have but I have many large tube Kohler radiators.  20" high and around 8" deep I came up with 2.6sqft per section.  I have two that are 22" high and used 2.8sqft per section for those.
    Do you have any pictures or measurments?  They would help greatly.
    Weil-McLain EG-45 connected to 392sqft of radiation via two 2" risers into a 3" drop header and 2" equalizer. Using Rectorseal Steamaster water treatment to greatly reduce corrosion in the boiler.
    Steam system pictures updated 6/5/14.
    https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
  • Positive Solution Positive Solution @ 6:12 PM
    Contact this user
    Thin Tube
    The Kohler radiation that I have is thin tube about 19" high. It is the same radiation that is located in the Kohler brochure that is on the Heating Help website. The brochure is from the 1940s or 1950s.
  • kcopp kcopp @ 9:38 PM
    Contact this user
    if they are....
    19" high and 5" deep figure 1.75 sq ft....... if they are 7 " figure  2.25 sq ft. ea. section.
