The Wall
Forum / THE MAIN WALL / CPVC diameter conundrum...
  • Post a Reply to this Thread
    CPVC diameter conundrum... (4 Posts)
  • kcopp kcopp @ 3:59 PM
    Contact this user
    when to replace a water heater last week in a Mfg. home... I went to hook into the existing cpvc line w/ a SS water heater connector and the sharkbite fitting would not go on easy at all. In fact it would not even take a std. 3/4" cpvc fitting either. Piping appears to be 3/4" Flowgard gold, sdr 11... normal stuff. But it has a slightly larger diameter that will not get inside a fitting. I ended up making it "work" by using a 3/4" Sea-tek coupling that I shaved part of the inside out and jammed it on w/ everything I had. I am not comfortable leaving it that way for long.... any thoughts? I do not think it froze as CPVC has little resistance to freezing. ty,kpc
  • kcopp kcopp @ 10:20 PM
    Contact this user
    another thing....
    I did notice when cutting into the tubing w/ the cpvc cutter it was VERY brittle. It did not cut clean. I ended up having to use a pull saw to get a square edge.
  • bill nye bill nye @ 10:30 PM
    Contact this user
    pvc dia.
    Not schedule 40 ? Not CTS - copper tubing size?  Was it quest or cresline tubing? polyethelyne. Was it connected with copper crimp band type connectors?
  • kcopp kcopp @ 11:47 PM
    Contact this user
    It is/ was....
    glued just like all cpvc I have seen. Said Flowgard gold and had the yellow stripe along the edge.
    This post was edited by an admin on January 2, 2012 11:49 PM.
