The Wall
Forum / THE MAIN WALL / mono flow blues
  • Post a Reply to this Thread
    mono flow blues (5 Posts)
  • toolman toolman @ 8:05 PM
    Contact this user
    mono flow blues
    can a small pump be add to a mono flow. I have a 8ft of base board bout 30ft away. yes its below the main.
    sometimes i think i shooed had lunch some were else that day!
    This post was edited by an admin on January 10, 2012 8:29 PM.
  • JStar JStar @ 8:23 AM
    Contact this user
    RE
    Yes you can! In fact, that's how the principle of Primary/Secondary piping came into this world. You can read about that in some of Dan's books.
    Just size the pump for your connected baseboard run, and have it pump away from the Monoflo main on the loop's supply line.
    But, out of curiosity...has this ever worked properly? Was it added to the system?
  • Paul48 Paul48 @ 5:32 PM
    Contact this user
    Two monoflow tees, eight feet apart?
  • toolman1 toolman1 @ 7:51 PM
    Contact this user
    mono flow blues
    some one eles added the register to the mono flow loop,and never got it to work. So I was asked to fix it.I have worked on boilers,but never this type of system.Will try to fix in the morning.I will let you know what happens.thanks cold in Michigan.
  • Paul48 Paul48 @ 8:03 PM
    Contact this user
    red stripes
    If you are going to try using 2 monoflows, make sure the red stripes are facing each other.
