Does anyone
Make a storage tank. 3' high x 1' x 1'. Need some extra storage in a tight space.
What for?
What kind of application would this be? If for DHW, perhaps a flat plate heat exchanger would be the ticket.
This post was edited by an admin on January 19, 2012 6:41 PM.
I have an existing
Indirect, and need some extra storage.
well
That would be about almost a 18 gal. tank uninsulated and involve piping changes. Why don't you crank up the temp of the existing indirect and add a mixing valve to temper the out going water?
Vaughn
I used a couple of their stubby tanks years back. They were either 30-40 gallon tanks. They were great for crawl spaces. I would check into other brands though
Thanks all
I have a GB 142/30, and have tried setting the HW at max. Temporally, but I still run out, just need something to take care of the initial dump. I think I found something that will fit ,
Thanks guys. Will keep you posted.
