The Wall
Forum / THE MAIN WALL / Valve Actuators
  • Post a Reply to this Thread
    Valve Actuators (4 Posts)
  • Valve Actuators
    These valve actuators were originally available through Thermalese.  Does anyone know a source for replacements?
  • Anyone?
  • hot rod hot rod @ 3:15 PM
    Contact this user
    looks a lot like
    an earlier Wirsbo model, also. The challange if finding a replacement with the correct pin stroke. Then threads are all common, but the wrong pin dimension can hold the valve open, or not allow it to stroke enough to fully open.
    hr
  • tim smith tim smith @ 9:40 AM
    Contact this user
    I remember those damn things
    Wirsbo had lots of problems with telestats back about 18 yrs ago. They made 3 mods until they got one that the wire on the heat motor would not break from a bad solder joint.  I am pretty sure the Wirsbo non heat motor telestat will fit right on there. You also adjust the pin position by rotating knurl nut until pointer lines up with green dot. Still available. Good luck
