The Wall
Forum / THE MAIN WALL / honeywell actuator
  • Post a Reply to this Thread
    honeywell actuator (2 Posts)
  • chuck172 chuck172 @ 4:45 PM
    Contact this user
    honeywell actuator
    Does anyone know if I can use a Tekmar Mixing Setpoint Control 153 to control a honeywell M6063 Actuator and V5442 Compact Rotary 4 way Valve?
  • STEVEusaPA STEVEusaPA @ 9:39 PM
    Contact this user
    I don't see why
    I don't see why you can't. Any reason why you don't want to use the recommended AQ-675? Should be compatible with any PID control, like Tekmar. I would call Honeywell just to double check.
    steve
