Forum /
THE MAIN WALL /
Changing blast tube lenght
Post a Reply to this Thread
Changing blast tube lenght (6 Posts)
I may be in the market for a new Riello burner. Mine is 25 years old and needs some major repairs, blast tube and motor. I see that burners come with different length blast tubes. I have an 8 inch now but because of the burner location a shorter tube would fit the boiler room better. Could I replace an 8 inch with a shorter 5.5 inch assuming I replace the complete unit and a shorter tube would not cause maintenance interference problems? -
My Understanding.
My understanding from reading Beckett documentation intended for retrofit applications is that you should choose the burner tube length to match your application (insertion depth). So, I say go for it. Probably best to keep it as short as possible anyways, all else being equal. Pensotti uses the USBT in one of their boilers. -
Tube length
I would not change the length. I know some of the manufacturers have had problems with Riello and the only change Riello had to make was tube length. I do believe it may be more of an issue with positive draft boilers as opposed to negative draft boilers. -
Would be more comfortable..
Would be more comfortable lengthening it than shortening it.
What boiler is this for? -
boiler type
The boiler is a Utica Starfire 2 without the swing out door running a .65 nozzle. 91K btu. -
Can't see..
Can;t see a manual for it. I think the boilers that needed a longer tube were Buderus and they only did that when they changed their insertion depth. The starfire doesn;t run positive pressure so there shouldn't be an issue using a shorter tube if you maintain insertion depth. But then, crazy things can happen.
