The Wall
Forum / Strictly Steam / Radiant floor with steam
  • Post a Reply to this Thread
    Radiant floor with steam (2 Posts)
  • malex malex @ 10:55 AM
    Contact this user
    Since insulating the mains I miss the the radiant floor effect I had going in the galley style kitchen from the main running directly under it. I am wondering if there is another way to steal some heat from the main? I've thought of a couple screwball ideas:
    1. Remove a slit of insulation from the top of the pipe (but this may have detrimental effect to the insulation value and once I finish the basement ceiling heat will be deflected)
    2. A runout to go into the joist bay and act as a hidden radiator (you probably don't want the steam pipe against the floor plank boards though)
    3. Aluminum plates against the floor that are attached to the main to conduct heat
    Maybe these are just 'pipe' dreams but I sure I am not the first to think about it on the wall?
  • Tim_Hodgson Tim_Hodgson @ 4:21 PM
    Contact this user
    I like
    your idea of the pipe radiator in the joist bay. Just be sure to support,  pitch, drip and vent the pipe properly. I would guess that one 1/2" pipe is more than enough heat supply for one joist bay.
    Good luck,
    Tim
