Post a Reply to this Thread
Outdoor Reset (5 Posts)
Outdoor Reset
Any recommendations for an outdoor reset that can be used to adjust both baseboard/ DHW and in slab radiant heat.
I have 3 way manual adjustable mixing valves for the floor heat. Would I need to purchase new mixing valves that are adjusted by the outdoor reset.
Thanks in advance.
Tekmar
Tekmar makes great products for this application. I would put the DHW on priority then use a motorized mixing valve controlled by the tekmar for the radiant . Many manual valves can be adapted with a motor.
honeywell am
is there a particular control system/motors for the use with these types of mixing valves ?
Before you....
do that..... what do you have for a boiler? Baseboard usually is not mixed down.
The valve I like to use is the Taco iValve.... it does outdoor reset and mixes all in one easy package.
Smith GV100
with baseboard and in floor radiant (concrete slab).
