Forum /
THE MAIN WALL /
Heating Alert! - Taco
Post a Reply to this Thread
Heating Alert! - Taco (8 Posts)
00R
Its my understanding that this new pump is just a 00R with a new name. I thought it might have been their anwser to the Grundfos UPS26-99 but was told its just the current 00R."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price." -
00R, and the new 0015
Hi Chris
The new 0015 is not the same as the 00R. The 0015 is an all-new family platform using single speed, 3-speed and variable speed motor options for a wide range of Hydronic, Radiant and Solar Thermal applications. It also includes a new Stainless Steel casing option for use on Domestic Hot Water recirculation (DHWR) and other open fresh water applications. Both casing materials come in standard in-line or rotated flange options and include an Integral Flow Check (IFC) as standard.
The Cast Iron 0015 3-Speed is a direct replacement for the current 00R 3-Speed and the Grundfos UPS15-58FC, B&G NRF-25 and Wilo Star S21F etc. A Stainless Steel 0015 3-Speed version is a direct replacement for the Grundfos UPS 15-35SF and UPS15-55SF for DHWR and opens fresh water systems.
With the addition of Taco’s Variable Speed control options, the 0015 can be adapted to many other applications including 0015-VDT for maintaining a constant system Delta T, 0015-VR (Outdoor Reset) or 0015-VS (Set Point) for Radiant injection mixing or 0015-VT for Solar Thermal systems.
The existing 00R-3-Speed s will be discontinued, effective June 2012 and replaced by the more universal 0015 for a wider range of models, options and system applications.
joe mattiello -
But does it have great curves?
Can't find the curve chart for this circ, Joe- can you dig it up for us?"Reducing our country's energy consumption, one system at a time"
Baltimore, MD (USA) and consulting anywhere. -
Thanks
for the quick response!"Reducing our country's energy consumption, one system at a time"
Joe
Its the same curve as the 00R. What is the benefit of using this pump over the existing 00R? I was hoping this pump was in addition to the 00R to match the Grundfos 26-99 3-speed."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price." -
0015 attributes
Chris, I have explained the attributes of the 0015, when comparing it to the soon to be obsolete 00R.
The 0015 includes a new Stainless Steel casing option; both casing materials come in standard in-line or rotated flange with an Integral Flow Check (IFC) as standard. As you mentioned the Cast Iron 0015 3-Speed is a direct replacement for the current 00R 3-Speed and the Grundfos UPS15-58FC, B&G NRF-25 and Wilo Star S21F etc., but it is not equivalent to the Grundfos 26-99.
The now available Stainless Steel 0015 3-Speed version is a direct replacement for the Grundfos UPS 15-35SF and UPS15-55SF. Another, cool feature available for the 0015 is the variable Speed control options, including the 0015-VDT , delta T, 0015-VR outdoor Reset, 0015-VS set point, or the 0015-VT solar thermal pump.
So when you say they are the same pump, you mean the performance characteristics only; right? Obviously, the 0015 has many more available features to handle most of your application needs, which is why the 00R pump is going away.joe mattiello
