The Wall
Forum / Strictly Steam / Soft water for 1919 tube steamer make up?
  • Post a Reply to this Thread
    Soft water for 1919 tube steamer make up? (2 Posts)
  • Timco Timco @ 11:45 PM
    Contact this user
    Customer has a 1919 huge tube steamer. It's had a few tubes reolaced and the returns are rotted in a few places. One pipe.
    They had another guy tell them a water softening system will make this thing last way longer and will remove deposits from the system.
    Opinions from the pros??
    Thanks, Tim
    Working on steam and hot-water systems isn't rocket science....it's actually much harder.
  • nicholas bonham-carter nicholas bonham-carter @ 12:40 AM
    Contact this user
    way longer
    if this boiler is at the stage of tube replacement, then it is not a spring chicken, whose life-span will be increased by some magic chloride atoms from a softener.
    better to reduce any abnormal need for makeup water instead of softening.--nbc
