The Wall
Forum / Radiant Heating / Eliminating a section of baseboard radiator
  • Post a Reply to this Thread
    Eliminating a section of baseboard radiator (2 Posts)
  • SMattC SMattC @ 12:45 PM
    Contact this user
    Hey all, quick question. I have what I believe to be a monoflow radiant baseboard heating system. I took a look at the piping under the house, and there's a large main line and the radiators seem to be connected to that by smaller copper lines. What I have is a baseboard unit on a corner, and what I want to do is eliminate one ell of that corner. In the monoflow system, can I simply turn the valve off at the supply side of that radiator and then remove what I want to, or do I have to drain the entire system?
  • Dan Holohan Dan Holohan @ 10:43 AM
    Contact this user
    Unless you have a valve on both sides
    You'll probably have to drain the system.
    Site Administrator
    dan@heatinghelp.com
    Hug your kids.
