The Wall
Forum / THE MAIN WALL / Steam Boiler Changeout- Estimating Fuel Cost Savings
  • Post a Reply to this Thread
    Steam Boiler Changeout- Estimating Fuel Cost Savings (17 Posts)
  • Paul Pollets Paul Pollets @ 1:44 PM
    Contact this user
    A residential customer in Seattle asked me how much would he save by changing his oil-fired steam boiler (c.1980) to a new nat. gas steam boiler. The current boiler is firing at 1gpm into an uninsulated chimney. There are 9 radiators on a 1 pipe system.Basement mains are missing 90% of insulation.
    Current prices for fuel oil are $4.20/gal and nat. gas is $1.06/therm. I couldn't find any software that was anywhere near accurate for comparisons.What would you say?
  • Robert O'Brien Robert O'Brien @ 4:48 PM
    Contact this user
    How many gallons?
    How many gallons of oil do they burn? Take the gallons and multiply by 1.35 and you will get the equivalent therms.
    Contact this user
    How many gallons?
  • gennady gennady @ 6:07 PM
    Contact this user
    oil to gas savings
    1 gallon of oil contains 140,000 btu, so cost of 100,000 btu will be $4,20/1.4=$3.00 per 100,000 btu
    100,000 btu is 1 term. so cost of heating will go down 3/1.09 = 2.83 times
    Gennady Tsakh
    Absolute Mechanical Co. Inc.
    www.highefficiencyboilersNYC.com
  • Tim McElwain Tim McElwain @ 7:24 PM
    Contact this user
    Paul contact
    me by e-mail at gastc@cox.net and give me a fax number and I will send you a little chart that will do the trick.
  • Zman Zman @ 9:28 PM
    Contact this user
    % Efficiency
    You also need to factor in the efficiency of the Boiler.This is easy to do with the attached sheet. The insulation number will require a bit of a SWAG.
    Gennady is absolutely correct assuming the new boiler is no more efficient and you do not insulate.
  • Steamhead Steamhead @ 10:48 PM
    Contact this user
    Might want to look at
    a conversion burner. What make and model is the boiler?
    Reducing our country's energy consumption, one system at a time.
  • Paul Pollets Paul Pollets @ 2:30 PM
    Contact this user
    Existing boiler
    The existing boiler is not in good shape.
    The actual oil usage averages 566 gallons per year at $4.09 gal. based on 2 years worth of bills.
    I'd have recommended a conversion burner if the appliance was in better shape.
  • Robert O'Brien Robert O'Brien @ 5:27 PM
    Contact this user
    566 gallons
    That's approx 780 therms.
    Contact this user
    566 gallons
  • Steamhead Steamhead @ 11:28 PM
    Contact this user
    When you replace the boiler
    stay with a wet base/power burner type, for best efficiency. We use Smith 8 (the red one) and Slant/Fin Intrepid (blue one) series boilers with either Carlin EZ-Gas or Midco EC burners. Both EZ-Gas burners pictured have acoustic covers.
    This post was edited by an admin on July 6, 2012 11:29 PM.
  • Ron Jr. Ron Jr. @ 8:26 AM
    Contact this user
    $1.06 a therm ?
    Is that with all costs included ?  I just bought 200 gallons of oil at $2.91 , but that price difference makes it a no brainer .
  • Jean-David Beyer Jean-David Beyer @ 9:20 AM
    Contact this user
    My latest gas bill, due July 12, 2012, is
    4.22 Therms Gas        $2.47
    4.22 Therms Delivery $2.18
    Customer Charge       $8.25
    Total $12.90.
    Per therm:
    $3.0569 all in.
    $0.5853 for just the gas
    $1.1019 for gas and delivery
    This is in Monmouth County, NJ.Only use is for domestic hot water indirect from my mod-con boiler. It is going up to 100F outside, so none is for heating the house. ;-)
  • Mark N Mark N @ 11:11 AM
    Contact this user
    Gas Price
    The price I paid for natural gas on my last bill was $.97 a therm plus $5.99 service charge. The service charge is the same whether I buy 1 therm or a 100 therms.
  • SWEI SWEI @ 1:15 PM
    Contact this user
    out here in the West
    Things are a bit different http://www.nmgco.com/Current_Natural_Gas_Rates.aspx
  • David Sutton David Sutton @ 1:32 PM
    Contact this user
    Hi Paul,
    I go with Steamhead, i wont put in a log burner for gas, only wet based oil blocks with the carlin E-Z gas, avg about 84% eff compared to 79 to 80
  • gerry gill gerry gill @ 1:33 PM
    Contact this user
    And if you really want to increase efficiency
    Insulate the pipes and fittings, and upgrade the venting.
