The Wall
Forum / Gas Heating / Jumper wire in Vent Damper receptacle on Laars mini-therm JVT75N boiler
  • Post a Reply to this Thread
    Jumper wire in Vent Damper receptacle on Laars mini-therm JVT75N boiler (2 Posts)
  • asher asher @ 8:23 AM
    Contact this user
    Hi, I was wondering if someone could help me please.
    I have a Teledyne Laars mini-therm JVT75N boiler and the jumper wire in the power venter/Vent Damper receptacle got accidentally pulled out. I put it back according to diagram A in the installation document C1056A however I have now realized that my receptacle is actually turned 180 degrees from the picture. This means that I actually put the jumper wire between the Y and O wires in the receptacle! See Figure 9c on page 12 of this document for wiring diagram
    http://www.gogeisel.com/geiselonline/support/Laars/Mini_Therm_II_Model_JV.pdf
    When I turned the boiler back on and the thermostat turned on there was loud clicking noises every 0.5 seconds. I quickly turned the boiler off and eventually found a wiring diagram that showed my mistake i.e I had put the jumper wire in wrong. I have now managed to put the jumper wire where it should be but now when the thermostat turns on I can see the zone valve open very slowly but the boiler does not come on.
    Is it possible for you to predict from the wiring diagram what I might have damaged by putting the jumper wire wrong? Have I damaged the zone valves or the zone pump relay?
    I think the loud clicking noise is the same as when the thermostat usually turns on but I am not sure if that noise normally comes from the zone valve itself or the zone pump relay?
    Many thanks for any help you can provide.
    Rich
  • asher asher @ 10:27 PM
    Contact this user
    Issue resolved
    Sorry, I got a bit over paranoid about my issue and wasn't thinking straight. Checked the boiler fuse and it was blown. Replaced it and everything is working fine.
