The Wall
Forum / THE MAIN WALL / Maximum height
  • Post a Reply to this Thread
    Maximum height (8 Posts)
  • sprinter sprinter @ 8:39 PM
    Contact this user
    Maximum height
    Is there a maximum height a floor standing boiler Can be Off the floor.
    We have always Installed on a 4 inch or 6 inch pad.
    Because of all the floods one customer has asked We install 18 inches off the floor
    Never done this, but could not find anything to prove it could not be done.
    Thanks guys
  • JStar JStar @ 8:41 PM
    Contact this user
    Height
    Depends. Is it steam or hot water? How how is the ceiling? Hot water...no problem. Steam...potential problems. You need to maintain some critical dimensions with steam. For either, you need to ensure proper vent connection pitch.
    - Joe Starosielec
    Metuchen, NJ
    This post was edited by an admin on November 2, 2012 8:41 PM.
  • sprinter sprinter @ 7:59 AM
    Contact this user
    Thanks for responding
    Sorry I was not clear it is hot water it will work fine mechanically
    I could not find any code That's called for a maximum height under a freestanding boiler
  • sprinter sprinter @ 9:44 AM
    Contact this user
    Bump
  • sprinter sprinter @ 5:47 AM
    Contact this user
    Anybody
  • billtwocase billtwocase @ 7:09 AM
    Contact this user
    I doubt there is a maximum
    EK boilers must be close to that with the stands. I had boilers in attics due to location. As long as it is safe/secure, and all relief valves piped to code, and unit can be serviced, I can't find anything. I have always installed on 4" solid cement blocks. If it is a flood zone, check with the building dept.
  • bill bill @ 10:04 AM
    Contact this user
    As far as I can tell
    with all the flooding hoopla on the the east coast, the higher the better!!
  • Eric Eric @ 10:10 AM
    Contact this user
    as long as the boiler
    As long as the boilers supported properly on a stable base, (non-combustible), there is nowhere that says you can't raise it to the ceiling, as long as piping things mentioned above are not an issue and proper clearances are kept.
