manifold gage/w min/max- drag- tattle tale, indicator/pointer
in search of referenced item. many years ago a replacement lens was offered with a pointer, that would be moved by the existing gage needle to record the highest OR lowest pressure that was sensed, to help trouble shoot intermittent problems. i understand there are geekier ways to record this reading available. however, they all have one shortcoming or another that this simple add-on lens overcomes, for my purposes.
i know there are gauges available with this indicating feature, the ones i've found would work but they aren't standard manifold size or range.
yes, i'm being picky. but surely there are other gray beards out there that remember this simple, inexpensive problem solving tool. any help would be greatly appreciated.
thanks in advance
murph 50
