The Wall
Forum / Solar / Solar thermal connection to Burnham V73
  • Post a Reply to this Thread
    Solar thermal connection to Burnham V73 (3 Posts)
  • WildBlue WildBlue @ 11:47 AM
    Contact this user
    Want to optimize solar thermal hot water with Burham oil-fired boiler; thoughts on where to connect; from thermal storage to boiler; from thermal collector to boiler to thermal storage...  I would like to use the boiler as backup for hydronic heating; using the solar hot water first domestic hot water and second for heating.  I'm thinking that if I could keep the water temperature in the hydronic system constant at say 100-120 F ambient would stay constant, boiler would be used less.  Any and all thoughts welcome please...
  • Charlie from wmass Charlie from wmass @ 3:29 PM
    Contact this user
    Use a buffer tank
    pipe the heat sources in and out through the buffer tank and apply proper controls.
  • hot rod hot rod @ 10:12 PM
    Contact this user
    a number of ways to do that
    do you make DHW with the boiler now? Unless you have a fairly large array, and some low temperature heat emitters, you may not get much solar contribution, to the heating system.
    You could run a solar simulation and determine how much collector area would provide how much energy in your location.
    But DHW pre-heat is a good year 'round use for solar.
    Here is a book full of piping options for solar combi systems.
    http://www.caleffi.us/en_US/caleffi/Details/Magazines/pdf/idronics_6_us.pdf
