cast iron radiators
I am installing a cast iron radiator and I am not sure if there is a right or wrong way for the in or out pipes. I have a bottom to bottom set up and just want to know which way to flow the water.
rad connections
The most ideal way to pipe them is in top/out bottom. Bottom in/bottom out will work but depending on the rad you would reduce it's output by 5-10%
If you're wondering about flow direction, it doesn't matter.
This post was edited by an admin on November 13, 2012 12:55 PM.
