AquaHeat Manifold Question
We have an existing system using these manifolds and now would like to split it into 2 zones. Was hoping to add "Zone Valves" to the top of the existing valves - I have seen similiar things used, but have never installed them.
Any ideas would be great - Its in a tight location, making additional piping tough.
Thanks
Ed
manifold
you can put the heat motor actuator on the manifold loops you want to control. you will have to wire the t-stats to bring on the pump / boiler / zone valves. ect.
