The Wall
Forum / THE MAIN WALL / A GFCI receptacle as a LWCO
  • Post a Reply to this Thread
    A GFCI receptacle as a LWCO (5 Posts)
  • bill bill @ 5:40 AM
    Contact this user
    So it's 10 p.m. last night and 13 degrees out. A neighbors house sitter calls and says the heat is out.
    The system had glycol and the make up was off. It did not have a LWCO.
    What it did have was a leaking boiler drain at the boiler return. As the fluid leaked out the pump ran dry and tripped a GFI the boiler was plugged into.
    The pump was ruined but the boiler lives on. What a twist! A major company was there in Sept.
  • Steamhead Steamhead @ 9:26 AM
    Contact this user
    Can't make this stuff up
    this might be a good place for ME's "pig" setup as well as a LWCO.
    Reducing our country's energy consumption, one system at a time.
  • HDE HDE @ 11:03 AM
    Contact this user
    Wet rotor?
    You dont mention what type of circulator but it happens often. The pump windings shorted to ground and tripped the GFCI.
    Contact this user
    Wet rotor?
    Contact this user
    Wet rotor?
    Duplicate post from ipad
    This post was edited by an admin on November 17, 2012 11:04 AM.
