The Wall
Forum / Solar / Low watt pump
  • Post a Reply to this Thread
    Low watt pump (9 Posts)
  • oldsolar oldsolar @ 10:59 AM
    Contact this user
    Low watt pump
    I’m looking for low watt pumps, line AC most of the time with solar inverter AC power during outages. Minimum power consumption is the goal. As planned, the system will be ½ “copper pipe, drainback to 10G atmospheric pressure tank, head to collector 6’.The second loop is the HX in drainback tank to 80G storage, head from storage to drainback tank HX is 9’. I’m looking at Taco 007 1/25hp at 80w.I would like a lot lower consumption. How can I get there? Any suggestion would be great.
    This post was edited by an admin on November 19, 2012 11:02 AM.
  • SWEI SWEI @ 11:02 AM
    Contact this user
    AC powered ECM pump
    Check out Laing Thermotech http://completewatersystems.com/product/e-series-brass/
    Also available with a B&G label.
    This post was edited by an admin on November 19, 2012 11:03 AM.
  • hot rod hot rod @ 4:25 PM
    Contact this user
    Grundfos Alpha
    is what i have on a couple of my DB systems. It has 3 fixed speeds and consumes about 1/2 of a standard wet rotor circ.
  • Kevin_in_Denver Kevin_in_Denver @ 4:37 AM
    Contact this user
    Only Friction Head on Second Loop
    On the second loop, you don't need a pump with 9' head capability. That loop is full of water all the time and it's at city pressure. So you just need to overcome the friction head at a flowrate of 1-3gpm.
    This pump is worth looking at for the second loop because it only pulls 9W :
    www.sun-pump.com
    Superinsulated Passive solar house, Buderus in floor backup heat by Mark Eatherton, 3KW grid-tied PV system, various solar thermal experiments
  • oldsolar oldsolar @ 8:14 AM
    Contact this user
    Low watt pump 12v
    Those 12v low use pumps look good. Could be wired directly (through controller) to bat bank with reasonable gauge wire. Now I understand about head and friction head which means designing for lowest energy use is more doable.
  • oldsolar oldsolar @ 11:21 AM
    Contact this user
    more on low energy pumps
    Does anyone know were “sun-pump.com”went? I can’t seem to access the site.
     Low consumption 12v small size hot fluid pumps seemed just right. Any ideas on another maker of a pump with spec like theirs.
         12 to 24 v dc @ .8 amps 2.6 gal per minute, max lift 7’6” or 1.2 amp for 9’ 11” lift.
  • hot rod hot rod @ 10:42 PM
    Contact this user
    several choices
    March, ElSid, B&G/ Laing. the B&G Laing is a very nice, high efficiency pump, 8-30V I believe.
  • Kevin_in_Denver Kevin_in_Denver @ 3:21 AM
    Contact this user
    Chinese Topsflo Pump
    http://www.amazon.com/GPM-8-5-LPM-Solar-Water/dp/B0075J5GEY/ref=sr_1_1?s=hi&ie=UTF8&qid=1362039584&sr=1-1&keywords=topsflo+pump
    Contact this user
