The Wall
Forum / Controls / Electric Baseboard HeatThermostat
  • Post a Reply to this Thread
    Electric Baseboard HeatThermostat (4 Posts)
  • EBEBRATT-Ed EBEBRATT-Ed @ 10:20 AM
    Contact this user
    i am looking for an electric baseboard heat thermostat, programmable, either 7 day or 5/2 day. All the ones I have seen are 2 wire single pole. The existing stat is two pole and I beleive that these thermostats are supposed to have a positive off position. So does a two pole programmable with a positive off exist??
    thanks for the help,
    Ed
  • SWEI SWEI @ 11:31 PM
    Contact this user
    TRIAC based stats
    Typically wire into one leg of the power feeding a 240V baseboard strip.  The other leg is wired to the supply.  Since it is a series circuit, this gives the stat complete control.  Circuit protection is still on both poles.
  • Zman Zman @ 8:49 AM
    Contact this user
    HoneywellAube
    I believe Honeywell / Aube t-stats break both poles. They also have a nice vacation mode that can be controlled remotely.
    Swei is correct that many t-stats used are single pole and the turn off the heaters just fine. There are 2 pole models out there. I prefer them
  • Empire Empire @ 4:33 AM
    Contact this user
    T-Stat.
    ALWAYS use 2 pole for 240 vac stat on electric base heat.  The reasoning behind this is if the element shorts out and breaks 1 of both legs, the shorted leg will continue to heat uncontrolled.on the other leg of the 240vac.
    Mike T.
