Post a Reply to this Thread
Water in Sight glass on steam boiler goes down 1 1/2 inch a day (4 Posts)
Hi, I have a question my pennco 1660 hsd steam boiler, one pipe system I notice the water level in the sight glass goes down about 1 and 1/2 inch a day which causes the water feeder to kick in and bring it to regular level. I'm worried this is not normal and am not sure what to do. The heat works fine and all radiators heat well. I do not see any leaks or water around radiators or boilers. Last year I had return pipes replaced. If anyone can advise me on what I can do. Thanks. V
disappearance of water
if the water never comes back, then it must have gone somewhere. underground leaks are not readily visible,
if you look at your chimney, while the boiler is firing, can you see steam?--nbc
Are you sure
Short cycling due to moderate weather will cause a slow water return. Are you sure the feeder is coming on or does the water just return as it should?
Waterline gets lowered
See if you can valve off the water-feeder, and see if the water is indeed disappearing over a few days. That would point to a leak, instead of slow returns.--NBC
