The Wall
Forum / THE MAIN WALL / Teflon tape, applied correctly.
  • Post a Reply to this Thread
    Teflon tape, applied correctly. (8 Posts)
  • Teflon tape, applied correctly.
    And it wasn't leaking!
    Often wrong, never in doubt.
  • bill bill @ 12:59 PM
    Contact this user
    It's drawing outside the lines
    That fiberglass insulation on the flue pipe is yet another example :)!
  • Jack Jack @ 2:02 PM
    Contact this user
    Well, Jeez, Alan
    He had some left over at the end of the job. You can just see the process. "Now, where can I put this?"
  • Paul48 Paul48 @ 2:34 PM
    Contact this user
    Details! Details!
    They said to use teflon tape, so he did.
  • Mark Eatherton Mark Eatherton @ 6:14 PM
    Contact this user
    Reminds me of a story...
    When my dad was young (40ish) he owned a small plumbing shop that had a retail store front. (Thank you SBA...) He hired a retired person to run the "store front" operations, which sold faucets, pipes valves, fittings etc. A customer showed up one day and said they had a leaking bathroom faucet. Ol' Roy grabbed a can of RectorSeal pipe dope, and on the outside of the can it said "Stops Leaks".
    The consumer took it home, and painted his faucet with this extremely sticky pipe dope, to no avail. The consumer called my dad and complained. My dad went to his house and installed a new faucet for free...
    Ol' Roy never ever sold another can of that stuff....
    By the way, do you know what PTFE stands for? Plumbers Tape For EVERYTHING!
    (Thanks Moby!)
    ME
    It's not so much a case of "You got what you paid for", as it is a matter of "You DIDN'T get what you DIDN'T pay for, and you're NOT going to get what you thought you were in the way of comfort". Borrowed from Heatboy.
    This post was edited by an admin on November 30, 2012 6:19 PM.
  • unclejohn unclejohn @ 9:45 PM
    Contact this user
    The trouble here
    Is thats the gas line.
  • icesailor icesailor @ 7:51 AM
    Contact this user
    Gas lines:
    That's not the gas line. it is either the cold or hot water inlet for the tank. It is one of those "Quickee Connects" that some use to connect water heaters. I guess they are also requires in earthquake zones to allow for movement.
    Some jurisdictions (Massachusetts) require a vacuum relief valve on the cold water inlet to the tank to protect against tank collapse.
    Another stunning use of PTFE Tape. To some, it is like Duct Tape without the sticky side.
  • TonyS TonyS @ 10:00 AM
    Contact this user
    Of course it wont leak
    A homeowner did it. Just like they screw a 1/2 inch fip adp onto a shank faucet and it doesnt leak. always amazes me!
