Burnham Damper Problems
I have a new Burnham ES25 Gas fired boiler which is vented into a lined chimney. The boiler will not fire which I have been overiding by pushing the reset buton on the rear of the boiler. My plumber has said he believes it could be problemswith a clogged chimney and I am waiting for the chimney person to contact me. As I live on Long Island and the Sandy victims are numerous I don't know when the chimney inspection will take place.
Any suggestions or similar posts with this problem?
Whats the err code
Sounds like your reseting the blocked flue switch. Thats not a good thing to keep having too do. But you should get a "err" code on the display. What is it?
