The Wall
Forum / THE MAIN WALL / Utica steam and return pipes
  • Post a Reply to this Thread
    Utica steam and return pipes (6 Posts)
  • mikelutgen mikelutgen @ 12:23 AM
    Contact this user
    I have a 10 year old Utica Steam Boiler PEG150CIDE. The black, what appears to be cast iron, return pipes are springing leaks all through it's approximately 10 foot length. There are curves and couplers along the way. The pipe may be pretty old, as the house is 80 years old. What would cause this to all fail at once, and what is the most modern replacements for this pipe? I actually closed the valves off on some the radiators. could that have caused this problem?
    This post was edited by an admin on December 2, 2012 12:32 AM.
  • Paul48 Paul48 @ 7:41 AM
    Contact this user
    Wet Return
    If it is below the boilers normal water line, it is considered wet return, and is full of water all the time.It is common  to replace the wet return when the boiler is replaced, and obviously should have been done the last time yours was replaced.Below the water line can be replaced with copper.
  • JStar JStar @ 7:43 AM
    Contact this user
    Steam
    Old pipes leak. It happens. Closing radiators shouldn't have caused it. My only first reaction, if there are a lot of leaks, is that something may have triggered it.
    What kind of maintenance has been done? Do you have an automatic water feeder?
    - Joe Starosielec
    http://thatcherhvac
    http://facebook.com/thatcherhvac
    Guaranteed performance. Guaranteed energy savings.
    Serving all of NJ, NYC, Southern NY State, and eastern PA.
    Consultation anywhere.
    (Formerly "ecuacool")
  • mikelutgen mikelutgen @ 3:04 PM
    Contact this user
    auto water feed
    It has an automatic water feeder. PSE&G said it was probably the back pressure from closing off some radiators that blew out the old pipes.
  • JStar JStar @ 3:57 PM
    Contact this user
    Pipes
    That is...incorrect...inaccurate...umm....wrong.
    Do you have pictures of the boiler and piping?
    - Joe Starosielec
    http://thatcherhvac
    This post was edited by an admin on December 2, 2012 3:57 PM.
  • EBEBRATT-Ed EBEBRATT-Ed @ 5:41 PM
    Contact this user
    two things
    1. It may just have rotted out do to natural deterioration and age or
    2. If the system has other leaks, bad vents or traps or piping that has been leaking over time and the system has been adding a lot of make up water that will rot out anything below the water line quickley.
    After you get it fixed monitor the water consumption carefully. you don't want to loose the boiler next.
    Ed
