Post a Reply to this Thread
zone issue (5 Posts)
zone issue
i need to replace a zone valve with a circulation pump. Does anyone know how I would go about wiring the pump to the t/stat?
thanks
Yes
Via a switching relay.
Why?
You need a separate relay, flow check, and knowledge of piping. Why do you need to replace a zone valve with a circ?
Why:
Ditto (To the question of Billtwocase).
Yes
Get a RIB [relay in a box] break the 110v to the circ. through the normaly open contacts and wire the t'stat the 24v coil. Done
