niosy geothermal
We installed a Bosch TA035 geothermal heat pump this last month and it seems to have a lot of noise coming from the compressor . How can I tell if the compressor has some type of mechanical problem that is causing the excessive noise ?
Thanks A.J.
Shipping bracket?
Just a WAG. Usually a Copeland scroll is pretty quiet. Is it all the time? Startup?
noise
Is it 3 phase, if so try changing rotation
RJ
