The Wall
Forum / Domestic Hot Water / Rinnai R53i-1
  • Post a Reply to this Thread
    Rinnai R53i-1 (6 Posts)
  • Paul S Paul S @ 10:20 PM
    Contact this user
    Rinnai R53i-1
    hey everyone....i am having a problem with a rinnai tankless water
    heater model#r53i-1....they have intermittent problems with the hot
    water....for example it will lite then lockout 10 seconds later....then
    there will be times that it will stay firing while the water is being
    used for 20 straight minutes.....this rinnai water heater was installed
    by a unknown company...there is no digital display to view fault codes
    or adjust temp.....factory default for water temp is at 120f.....rinnai
    heater is vented vertically about 14 ft to roof(the condensate drain on
    the pvc vent has a plug in it , not drained)....i called the tech
    support line and the technician couldnt really help me because the
    digital display wasnt there....he asked me to checked the clear rubber
    hose connected to gasvalve which is connected i think to the combustion
    chamber and there was water in the tube????.....the technician told me
    it was a faulty gas valve(coil sticking??)....my question ishow would
    water get into that rubber hose ??? and does anyone think its a faulty
    gas valve???
                               Paul S
  • Aaron_in_Maine Aaron_in_Maine @ 5:33 AM
    Contact this user
    Gas valve
    Yep once water hits that vinyl tube going to the gas valve your valve it's done. If the unit is vented vertical you need to hook up the condensate drain on the vent or it will happen again. I had to fix one that did the same thing. The installer pitched the sidewall vent back to the unit instead of away from the unit.
    This post was edited by an admin on January 11, 2013 5:33 AM.
  • Paul S Paul S @ 7:25 AM
    Contact this user
    thanks Aaron
    I will replace gas valve and drain the condensate collector that's on top of the unit....but why do you think this just happened its been installed for seven years now without the condensate collector drained...
  • Aaron_in_Maine Aaron_in_Maine @ 11:41 AM
    Contact this user
    Not sure
    Is this unit in a cold climate? The one I fixed was only in for a year and a half but in the cold Maine winter it sped up the process it was condensing in the vent got down to the burner. When I got there water was in the tray under the burner.
  • Paul S Paul S @ 12:09 PM
    Contact this user
    yes
    Yes its in a cold climate...its in Staten island new York.....most of the venting Is inside the drop ceiling then its goes through a roof to the outside
  • Jack Jack @ 2:17 PM
    Contact this user
    Paul posted this on multiple topics
    The Main Wall, gas heating and here on DHW. All comments are not in one section, so
    http://www.heatinghelp.com/forum-thread/144551/Rinnai-R53i-1
