The Wall
Forum / A-C, Heat Pumps & Refrigeration / Compressor Burn out
  • Post a Reply to this Thread
    Compressor Burn out (7 Posts)
  • Jr FMart Jr FMart @ 7:00 PM
    Contact this user
    Compressor Burn out
    This is R-22 system for three door reach-in refrigerator. when a compressor burnout what happens to the refrigerant and oil? does the freon get contaminated and converts from what?
  • Techman Techman @ 5:40 PM
    Contact this user
    Burn baby burn!
    When the oil gets contaminated , it can develop hydrochloric ,hydrofluoric( etch glass anyone?) and olayic acids. It is my understanding that the freon does not get damaged.
  • Eugene Silberstein Eugene Silberstein @ 11:27 AM
    Contact this user
    Damaged refrigerant
    The refrigerant does get damaged, as the hydrofluoric and hydrofluoric acids are formed, in part, by the fluorine and the chlorine in R-22.
    Happy Presidents Day.... a little early
    Eugene
  • Techman Techman @ 6:11 AM
    Contact this user
    Damaged freon
    If reusing the damaged freon ,does installing acid neutralizing filter driers reconstitute the freon back into an acceptable condition? I recover the freon thru filter driers, put the freon back into the same system, install acid F/D's , and I have no known problems. I have no repeat comp failurers, on the same system, so I believe I'm doing the proper thing!
  • unclejohn unclejohn @ 7:28 PM
    Contact this user
    3 door reach in
    We are talking what 18oz of refrigerant? Put nice clean freon in and a clean up dryer on the suction side. Also put a hh dryer on the liquid side and sleep easy my friend.
  • Techman Techman @ 6:49 AM
    Contact this user
    18oz
    How about 18lbs.or 10lbs. And since I don't have any repeat burnouts I do sleep easy. Small stuff, no problem replaceing the freon.
  • unclejohn unclejohn @ 7:36 PM
    Contact this user
    18#s
    Must be satans three door reach in.
