The Wall
Forum / Radiant Heating / Warmboard vs. HeatPly Radiant Heat
  • Post a Reply to this Thread
    Warmboard vs. HeatPly Radiant Heat (14 Posts)
  • JerryS JerryS @ 5:10 PM
    Contact this user
    We're building a 1200 sq. foot art studio and want radiant heat.  One manufacturer, Warmboard, uses aluminum as part of their design, whereas HeatPly, the other manufacturer, does not but has more tubing spaced more closely.  We're wondering if anyone has an opinion about the pros and cons of these two products.
    Thanks in advance.
    Jerry
  • Gordy Gordy @ 6:58 PM
    Contact this user
    That's why
    Warm boards tubing centers are 12" because of the aluminum it spreads the heat evenly.
    So when comparing figure the extra cost of tubing and transfer plates to compare apples to apples, and the labor to lay it if you are not doing it yourself.
    Never heard anyone complain about warm board.
  • JerryS JerryS @ 3:05 PM
    Contact this user
    Is an aluminum based radiant heat system signifcantly more energy efficient?
    Thanks. Would the aluminum make the radiant heat system more energy efficient over a system that does not have aluminum?  That is, in a relative small space of 1200 sq. ft.would aluminum allow the system shut down more quickly because it heats up a room faster and could you keep the water temperature lower? The cost difference is significant between ones with aluminum and ones without.
  • Gordy Gordy @ 8:07 PM
    Contact this user
    Plates.
    Aluminum plates, or sheeted panels will make the emitter more efficient by allowing a lower supply temp, and a faster response time.
    So to answer your question yes.
    You need to do,a,room by room heat loss first though. This will dictate several factors.
    1. The load of the house as a whole.
    2. The load of each room.
    3. Supply temps, and flow rate for the loops feeding each room, or zone.
    4. Whether radiant is feasable for the load on its own, or if supplemental heat is required.
    Control strategy for it all. This means zoning if desired.
    5. Size of boiler to meet these loads. Mod/con being the most efficient choice.
    Side note is floor coverings to consider for floor radiant.
    Low r padding with low r- value carpet.
    Wood floors, which ones welcome installation over radiant which I think is hog wash with a properly controlled low temp situation.
  • Gordy Gordy @ 7:23 PM
    Contact this user
    Or if You have Carpentry skills
    Make your own sleeper detail
    This post was edited by an admin on February 16, 2013 8:02 PM.
  • jonny88 jonny88 @ 8:44 PM
    Contact this user
    Gordy
    that is some pretty neat carpentry skills.any idea how long it took and what tools were used.very impressive
  • Gordy Gordy @ 11:52 PM
    Contact this user
    tools and Time
    Lets see Jig saw, circular saw, cordless impact.  About 16 man hours for about 320 sf.  8" oc no plates floor warming only. Ceiling radiant dominant emitter in the kitchen.
  • pipeking pipeking @ 8:15 PM
    Contact this user
    gordy
    i'm not knockin it but, y copper tubing?
  • Gordy Gordy @ 10:47 PM
    Contact this user
    Ahhh
    Knew that was commin.
    My house is built in the early 50's all ceiling, and floor radiant. copper of course. i did this before the price of copper went into orbit, and to keep the house in the era. Plus I like copper it's heat transfer properties are much better than pex.
    I did not due plates because the kitchen already has ceiling radiant which can handle the load on its own. But with tiled floors thought floor warming is a nice touch..... My wife thinks so.
  • pipeking pipeking @ 10:07 AM
    Contact this user
    bofore copper went imto orbit?
    when, so u bought the copper 20yrs ago!
  • Gordy Gordy @ 10:55 AM
    Contact this user
    Pipe king
    7 years ago. It may have been expensive then, but it jumped considerably since that time.
  • Gordy Gordy @ 10:59 AM
    Contact this user
    PS
    This house has 5000' of copper tubing and pipe. If the house ever burns down "joking" I got a savings plan in place.
  • keyote keyote @ 3:36 PM
    Contact this user
    i did something similar
    I just had home depot rip my plywood into
  • keyote keyote @ 3:37 PM
    Contact this user
